1 - 13 of 13 Posts
Hi all
Recently bought some new wheels for myself
however they are 5x114
I was planning on using wobble bolts to cure this but the bolt is too big for the wheel meaning I would need to drill the lug hole out slightly on the wheels to 16mm so the wobble bolts have enough room to move, which I don't fancy doing!
Now the bolt spec for our cars is M14x1.5 and the wheels I have are meant for M12!
I was wondering if I use a M14-M12 stud conversion kit then use regular M12x1.5 nuts if everything will fit okay?
In theory changing from M14 to M12 allows for 1mm of radial space which should be enough for 5x114 wheels
Has anyone done this or knows whether it would work or not?
Thanks and any help/advice is appreciated
You're dicing with danger there. You want to down spec the wheel studs on a 1500kg 155mph car?! Rather you than me
The safety side isn't an issue as I've seen people do it with 500bhp vehicles, I just wanted to know whether or not changing from M14 to M12 would give me a PCD of 5x114
Thanks for your reply though
Thought you would need to get the blts further away from each other, the centre of the bolt will still be in the same place no matter what size bolt you use ? I don't know much about pcds either but just a thought mate
PCD is measured from the centre of the hole so changing from M14 to M12 has no impact on PCD.
I would say adaptors are the way to go if the offset allows.
[/size]
This does make sense, and is what I thought but needed clarification
I think I'm going to bore the lug holes on my alloys out another 2mm which should allow me to use wobble bolts
Thanks for your replies guys
Mods can delete this thread
I am familiar with.wobble bolts and personally would never use them.
As I said earlier you can get adaptors as long as the wheel offset allows for their use.
Not sure what wobble bolts are but if never use them wouldn't true them , you must be able to get adapters
Offset will not allow for adapters
Wobble bolts are like normal bolts but the washer/seat can move 2.4mm either way, hub rings will insure everything runs true
1 - 13 of 13 Posts
