Hi there everyone I just bought a r32 which has done 120,000km. I was driving on the highway at around 120km/h for continuously for 10 minutes than all of a sudden I hear a beep and 3 sensors which is the ABS the ESP and Hand Brake showing in the speedometer. What could be the issue. Faulty sensor?. Please do advice as I’m a first vw golf owner.
Speedometer Vehicle Odometer Plant Trip computer
Instinct is to check the wheel sensors. There are four, one for each wheel. The cable and connector for each is the place to start . If all looks good, then perhaps a sensor. From VW they are quite expensive, so you need to be sure before beginning to replace. Aftermarket ones are available at a much lower cost . However, above checks first . If you can contact someone with VCDS on their laptop, then that will give a good indication of the source of the fault . That might be an even better starting point . Some specialist garages will have the software, and may be willing to do a quick plug in and diagnostic check . Or, for about £45, you can buy the cable and software, install on your laptop if you have one, and do the check for yourself. Given that you have an R32, I think that spending some cash on Vagcom will be a very good long term investment
I think that is your best starting point. You could spend a small fortune on new sensors and not solve the problem . I paid £45 for my lead and software . Took a bit of time to install on my archaic laptop but works well and is sooooo useful .
