1 - 6 of 6 Posts
has anyone with a vf engineering supercharger ever had any problems with it???
aslo do any of you get annoyed with the sort of rattly noise of the belts from the charger at very low speeds???
there is a bearing noise at iddle but its not a problem.
Running wise it has been faultless from the moment i turned the key. (I installed it myself)
Minnor Problems:
1. Belt slipping but once retensioned after 1000 miles for the 4th time! has been fine.
2. the fan rubbed through the boost pipe. This was my own fault from installation.
But thats it would not hesitate to recomend the kit.
Lee
This noise isn't always there for me.... It's as if the oil is too thin, I'm tempted to stick something a bit thinker in and see if it helps. Otherwise I have heard some of the guys in the states having the idle raised a tad.
So is there a nice supercharger whine when you drive along and up the revs?
yeah there is a great whine at low speed then when you boot it up you really hear it screaming!!!!its awsome!!!!!!!well worth the money!!!
1 - 6 of 6 Posts
