hiya ,,took my mk5 for a re-gas,,apparent after technician started the procedure that car had gas already although i was having it topped up when i was told the pump had failed thats the reason it wasnt blowing cold air!
that was a couple of days ago..earlier i took her to be cleaned and switched the air-con on and its blowing cold??
since the hot weather came in, up until today it was blowin out hot air! but now cold air,,car showed no faults whatsoever when it was put on vag,com,,
so i am a bit confused,,could it be the air-con pump is on its last legs? any ideas appreciated,,had it blasting out on the way home and it was lovely and cold? cheers jason p
