Turbo Mk4 R32 Carpro C.Quartz Ceramic Enhancement Detail
Products and equipment used
Uber microfiber towels
Chemical guy's woolly mammoth drying towel
3m yellow pads 150mm 75 mm
Halogen site lights
3m Yellow Polish
Makita rotary polisher
Carpro Sheepskin wash mitt
Carpro C.Quartz Ceramic UK Sealant
Carpro Dlux
Carpro Reload
CarPro Pearl
Carpro eraser
Carpro Ironx
3m masking tape
Meguiars APC
Costco microfibre towels
Valet Pro PH neutral Snowfoam
Britemax Max Clean Shampoo
Bilt Hamber clay bar
Autosmart Tardis
Various brushes
Kranzle pressure washer
Noodle wash mitt
Poorboys microfibre clothes
Uber buffing clothes
Snow foam gun
Glass Sealant
Britemax Metal Polish Twins
00 grade wire wool
Engine Bay Before
The wheels were cleaned using Carpro Ironx the was then given its first coat of snow foam whilst this was dwelling I went round the car using APC in a foaming head bottle cleaning the fuel filler area and various gaps and grills. The snowfoam was then blasted off with the pressure washer, and then the car was given another coat of the same mix snowfoam and the car was washed using the 2 bucket method with grit guards in both buckets and a Carpro lambswool wash mitt.
The car was then rinsed off using an open ended hose and I then went round the car with Tardis which was left to go to work before being wiped down with microfibre clothes. The car was then given a coat of Ironx again left to do its stuff before the car was washed down using the pressure washer.
Engine bay was cleaned with Megs APC a various detailing brushes before being rinsed with the pressure washer
The car was clayed using citrus bling and water mix (10 to 1) and a Bilt hamber soft clay bar which helped to pull more contaminates from the paint work it was then rewashed using the same method and dried using the woolly mammoth.
Snow Foaming
I then taped the car up and went round with various yellow 3m pads and 3m Yellow polish, each panel was given a wipe down with Carpro eraser after polishing to check finish and remove any polishing oils.
Engine Bay Dressed
