1 - 16 of 16 Posts
· Hard to reMember
Had a look, can't see anything for the R32?
· Hard to reMember
That's because they don't specialise in turbo kits for the R32 but instead specialise in turbots themselves, like Owen Developments.
So you could buy a Turbo designed for another car and stick it on? Or do you mean you can buy some sort of Universal turbo? Sorry I don't know anything on the subject
· Premium Member
You can use many different turbos that are used on different cars, obviously the correct brackets etc are needed.
Effectively build your own kit or for replacements
· Hard to reMember
Sorry should of put they don't do specific r32 kits but , if you are building a kit your self like I am they are rather cheap with a garret gt35r coming In at around £800
That's ok, it wouldn't have made any difference with my limited knowledge
The gt35r isn't designed or any specific car , it's like you say a universal turbo with the right manifold it can be fitted to almost any car
· Hard to reMember
I see thxs guys
So do people spend £10,000 for a specific kit for mechanical reasons?
· Nappy Wearing Member
"10,000" kits will include everthing needed, brackets, front mounts, turbos, hoses ect and the kit will be specifically made for that car for example tested and optimised so that not too much pressure is put on the engine but enough that it can maintain enough power.
Build your own kit and you have the risk of something going wrong but more than likely you build your own you have some knowledge.
· Premium Member
L_O_Z said:
I see thxs guys
I'd rather buy a kit, all the R&D has been done, reliability would be higher, there are many advantages to buying a kit.
One advantage to building your own anything for that matter is cost. But you would really need to know your stuff to mix and match
1 - 16 of 16 Posts
