Vag-Com Locations - With Clickable Links ;)
80785 Views 59 Replies 40 Participants Last post by  Sean.R32
I know there is another thread with vag-com locations. ive put them all on this list with clickable user links so people can contact the members easily http://www.r32oc.com/public/style_emoticons/#EMO_DIR#/wink.png
01.DWolfUK / mk4 & mk5, full VCDS & Vag-Tacho & VDS-Pro / Bedfordshire
02.Dodders / Full VCDS / Most VAG cars / Wiltshire.
03.N13KKF™ Hornchurch Essex area mkiv & mkv full vcds ross-tech HEX+CAN Genuine
04.Predator_R32 - Full HEX-USB+CAN - Durham Area
05.aRd Teesside area - Full HEX-CAN-USB-Latest Software / miles to empty , autowindows / alarm beeps etc.
06.Blackpug - MKiV Only / Lanarkshire, Scotland
07.JamesBaby - Genuine vcds, plus VDS and Vag Tacho. Plus Revo remap setting tweaks, data logging etc etc. - Huddersfield.
08.OllieR32 / Full VCDS (mkiv & mkv) on / Dorset (Bournemouth). Will travel for beer
09.simonmac - VAGCOM/VAGTACHO/VDSPro/Other stuff (mkiv/Some Audi's) / Gatwick/Brighton area. Will travel for Beer.
10.Stan.:R32 / mk4's & mk5's, vagcom & vagtacho / Rep.of Ireland (Munster)
11.alanbgt / Full VCDS / Somerset & Bristol
12.andy4motion - Genuine fully licensed Ross-Tech VCDS. Based in Cardiff.
13.DonkeyR32 - Full VCDS HEX & CAN latest version genuine RossTech,VagTacho for MTE & Illuminated needles Herefordshire Ross on Wye, Hereford, Ledbury, Leominster and surroundings will travel
14.MrPompey - Full VCDS / VAGCOM Forest of Dean, Gloucester.
15.andyboyohay - Genuine HEX-USE+CAN VCDS Pro kit Based in Pembrokeshire, West Wales.
16.silversonic - official Ross tech"VCDS" vag com based in halifax/wakefield
17.rwoody29 - vag com, fully licensed version for mk4's. can read and clear fault codes, not too confident on changing any settings though! Based in Stoke on Trent
18.B5-XPB - Genuine VCDS (VAG-COM) HEX-USB+CAN Interface Package Wolverhampton, West Mids.
19.amr_rm - I have VCDS 11.11.3 Located in the Warwick / Leamington Spa area Haven't had it long but I can scan and look at faults if required.
20. EZTutty - VCDS, VDS-Pro & Vag-Tacho - MKIV Only (Non Genuine Cable) \ Auto Windows, Anti-Hijack, Alarm Blips, Disable Selective Locking, Miles to Empty, Lit Needles, Accurate Real Time Temp Gauge. Derby
21.birdiemachine - Full VCDS - Central Northern Ireland
22.WillR32MKIVFull VCDS Axminster Devon
23.simonp VCDS MicroCAN only Wiltshire
24.Frankie32 VCDS Good for scanning and clearing codes Leeds
25.brend4nn VCDS Good for scanning and clearing codes Ipswich
26.VR6RichVCDS (HEX CAN USB-full version) and VagTacho Can do fault reading/clearing, logging, option setting, miles to empty, lit needles, welcome message, all for beer money Weston-Super-Mare
27.dazr32 - Full VCDS - Rhyl north wales
28.tamr32 Laurencekirk between Aberdeen and Dundee have genuine VCDS latest edition
29. scott88 fully licensed VCDS & Snap-On scanner / Whitehead, Northern Ireland.
30. Jamiew123Full Vagcom Goole East Yorkshire.
31. Dubzter - Full Blown Hex-USB+Can / The Highlands
32. Simes996 - Full VCDS 11.11 Hex-CAN-USB Romsey, Hampshire - Contributions gratefully received
33. Gr3asemonkey - VCDS Vag-Com Full HEX-USB+CAN based in Saffron Walden Essex
34. Youngsyp - full VCDS and am based in the Milton Keynes/ Towcester area and would be happy to help anyone.
35. R32Wilson - Full Genuine Ross-Tech VCDS Vag-Com HEX-USB+CAN / Hythe, Southampton
36. jaraz - Ross Tech VCDS HEX-USB+CAN Interface - All VAG cars - Kent
37. Jimmy - Full VCDS.Beccles, Suffolk. Will travel also.
38. Hanny - Ross Tech VCDS HEX-CAN-USB - Crawley, West Sussex
39. Ghost-Rider - Genuine VCDS, VAG CAN PRO, CARPROG, VAG TACHO - Redditch, Worcestershire
40. Jackwormuk - Rosstech VCDS // HEX-USB + CAN + Adaptors for older cars and vans Manchester Area
41. Steff - enuine latest version Ross Tech VCDS HEX-USB+CAN Interface - All VAG cars Located in East Sussex but also work in Kent.
42. Connolly3000 - VCDS. 1994-2014 Clear codes, check faults, auto lock and unlock and more. Bradford
43. Franko180 - Full latest/licensed VCDS HEX-USB+CAN, VAG Tacho, VAG Commander. Read / clear fault codes, data logging, anti-hijack, miles to empty, lit needles, welcome message (full FIS), alarm beeps, cluster coding, cluster repairs (replacing centre LCD due to heat fade issue), cluster swaps/coding/upgrades - half to full FIS, cluster LED changes, key coding, mileage correction, auto windows on remote keyfob, needle sweep on ignition (also known as needle staging). East Midlands.
I have up dated the list above..
Just so you know what to look for when considering people services etc below is a few of the basics that the different software can do http://www.r32oc.com/public/style_emoticons/#EMO_DIR#/wink.png
Vag-Com (VCDS) is required to do the lock/unlock beeps, auto lock/unlock, selective unlocking, SRI reset etc
Vag-Tacho is required to enable Miles to Empty, Lit Needles, Welcome Message
VDS Pro is required to reprogram the CCM to allow Window Opening/Closing from the keyfob http://www.r32oc.com/public/style_emoticons/#EMO_DIR#/wink.png
Reactions: 1
1 - 20 of 60 Posts
i can do mk4 and mk5 golf now as i have HEX CAN
hi paulie can you add vagtaco to my list please. cheers gaz
Hi, I'm new to the site, don't suppose there is anyone in the cambridge area with VagTacho, I want the miles to empty on my mk4 R32.....Am in saffron walden, cambridge/essex border....thanks
Derby...
Reactions: 1
I'm in Huddersfield but work in Oldham near the m62 if you need.
I am updating the list on the first page.
I have PM'd everyone on the list to see if they are still offering to use VCDS (Vag Com)
If there is anyone not on the list on the first page who wants to be on it PM me please with what you can do and location.
Just to add, I have the latest VCDS Vag-Com Full HEX-USB+CAN based in Saffron Walden Essex
Feel free to pm
I tried to add myself but get a key error.
I now have full VCDS and am based in the Milton Keynes/ Towcester area and would be happy to help anyone.
Paul
Paul
I have added you
DWOLFUK
Please can you add me to your list: Sonnywilson92 - Full Genuine Ross-Tech VCDS Vag-Com HEX-USB+CAN / Hythe, Southampton
Dammit! No one in west london area. Just had engine light come on on mine.
is your car running ok....if it is try disconnecting the battery for 20 mins....touch the cables together before you put them back on the battery
A safer way instead of shorting them is leave the car for 30mins to drain residual power
Yeah car seems to be running fine even though light is on. Came on sunday. Was there mon & tues. Not used it today.
So just disconnect them for half hour?
yes just take both cables off the battery...some times it works
Location Kent .
Reactions: 1
Location Kent .
Added
Add me please. I have full VCDS.
1 - 20 of 60 Posts
