1 - 8 of 8 Posts
Check out Page 7 here
This kit is available for both the MkIV R32 and the MkV R32 aswell as many other VAG vehicles.
MkIV R32 - takes power up to 335bhp this is a twin turbo kit
MkV R32 - takes power up to 350bhp this is a twin turbo kit
It may look similar to this setup below which was installed in a 2.8L Golf:
335bhp with bi-turbo? That's not a lot really is it?!
And I personally think that install looks feking horrible!
Each to their own I guess
Hmmmmmm.............. Judgment reserved for the time being. Not quite sure whether I like it or not and as Matt says, 335bhp ain't that much from a twin turbo especially when you consider you can get close to 300 from NA mods.
I think it looks really nice with the carbon fibre there, agreed on the power output tho seems very low for twin turbo but then a little research would seem to suggest it is a bolt-on kit and doesnt require removal of the cylinder head to fit a spacer as is the case with the HPA and C2 kits so in theory that would result in reduced installation costs.
Hummm, looks great but what works? No water bottle, no reservoirs at all.... In fact not a lot! I love the way the turbo pipes twist round though.... What’s the damage in £?
£3k including installation
Only joking, I'm not sure on the cost to be honest.
Also not sure why the 15bhp difference between the mkIV and markV which use the same capacity engine etc and are basically the same.
1 - 8 of 8 Posts
