1 - 20 of 28 Posts
I've had these in for a week and thought I'd do a review. I know other people have them and I hope I'm not repeating what's already been said. Vibratechnics aren't aware I'm writing this, I'm not getting any commission and I'm not biased, I'm just Jo Public sharing my experiences.
Let's start with the boring need to know stuff:
'Fast Road' part nos for MK4 (see link below for competition spec if you're brave):
VAG606M - LH mount (Gearbox)
VAG404M - RH mount (Engine)
VAG405M - Pendulum mount subframe end (aka 'Dogbone')
Optional 4th mount:
VAG455B - Pendulum mount (gearbox end)
Best price / most reliable seller I could find at time of writing, for the 3 main mounts:
C&R Enterprises (ebay shop) - £453 inc VAT & Delivery
Tools required:
Ratchet, extensions, 10mm, 13mm, 16mm, 17mm & 18mm sockets.
Philips screwdriver, trolley jacks, axle stands.
Procedure:
I didn't take pics as it was cold and I wanted to get it done, but there are plenty of pics online for changing the mounts. It's very straight forward.
Time to fit all 3:
Approx 2 hours.
Manufacturers link:
http://www.vibra-tec...tta_bora_mk_iv_
Why do I need these and why on earth are they so expensive?
I've owned and modified VWs since 1990. MK1s, MK2s, MK3s, Corrados and now a MK4, and have driven most other marks. One thing I noticed on all of them is how rubbish the standard engine mounts are.
Car makers have to make them very soft to meet NVH criteria (Noise, Vibration & Harshness). Who wants to buy a car that shakes your teeth out? The downside of soft mounts is excessive movement, and that's a lot of weight to be moving around under there. At best this causes wheel hop under hard acceleration and accelerates exhaust flex-joint wear, and at worst you have 220Kg (V6 engined Golfs) of pig iron swaying about in the corners, upsetting the car's balance. I'm not sure how many people realise how bad that is for handling and understeer! This is precisely why Engines are now stressed members in Supercars and why Porsche developed active engine mounts for the 991.
By pinning the motor down firmly, everything that matters improves. Handling, traction off the line and exhaust joints live a longer, happier life. The engine just gets on with accelerating the car instead of jumping about like a randy Walrus.
As I'm not a fan of poly on road cars, Vibratechnics were the natural choice as they've resolutely stuck with rubber over the years. They don't make stiffer versions of standard mounts, they completely re-engineer them and that's why they're expensive. They're also unique and do the job they're intended to do very well indeed. All this costs money.
And not only that, I like to support small British companies. Too much cheap tat is imported before giving the Brits a chance to mature their products. When you see them in the flesh, it's easy to see where the money has gone.
OK, sounds good, but what are the downsides, Newton's law of opposing forces and all that?
There is only one downside. That NVH I mentioned earlier. VT mounts have less than half the effective absorption area of the standard mounts. A smaller, stiffer piece of rubber is where the reduction in movement comes from. The forces not absorbed by the large, squishy standard mounts has to go somewhere, and it goes through the unibody and into the cabin as increased vibration and noise. The LH mount is the one most responsible for the vibration and noise because it's gearbox one, and Mr Gearbox is the noisiest and roughest part of the entire drivetrain.
You will often read on the internet of people fitting poly or solid mounts (and even mounts consisting of a spring and some wire wool in the middle) and their owners claiming there is absolutely no increase in NVH. In my experience that is completely false. You may not get increased NVH at idle, or say, 4000rpm, but you WILL get increased NVH somewhere in the rpm range. You can't cheat physics.
In extreme cases, very hard mounts can cause secondary harmonics severe enough to shake engine mount bolts loose! That happened to me on my Corrado.
Go on then, hit me with it, when will I feel this extra NVH?
With the Fast Road mounts and when they're cold, the increased NVH is strongest at 2500rpm. Everywhere else feels only a little harsher than stock, well, the idle on mine is actually smoother than stock.
But as the engine bay heats up and therefore the rubber in the mounts softens a little, the vibration and noise reduce quite significantly and at the end of a long journey you're not even aware of their presence.
From previous experience, the Competition spec mounts are not suitable for daily road use, but on a track, they really are the mutt's nuts.
I'm making them sound quite bad, but it's all relative and subjective. Compared to VF Engineering's poly mounts all round (which shake the dashboard!), these Vibratechnics are like Jelly and silent by comparison! I believe in accurate reviews and it would be wrong of me to claim the Vibratechnics don't increase NVH, because they do. Just nowhere near as much as poly mounts (in my experience).
£450 and increased vibration and noise, remind me again why I should get these???
OK, from the first turn of the key you are immediately aware there is no engine rock at idle. The engine now feels like an integral part of the car and not an overweight passenger who can't keep still.
Secondly, when you enter a corner, the engine just doesn't move at all. This means you can get on the power earlier with more traction and less power understeer. Stability into and out of the corner (especially bumpy ones) is much improved. You immediately forget there is a wayward lump of pig iron under the bonnet, trying to escape. There's a couple of sharp, bumpy corners on my daily commute and giving it the big un round those had me understeering into the other lane. Not any more.
Thirdly, zero wheel hop under brutal acceleration off the line.
Fourthly, that horrible shunt through the drivetrain in the lower gears as the throttle snaps shut / open - completely gone. Crawling along in traffic is no longer an irritating chore. Regular commuters will know where I'm coming from with that.
Fifthly, epic gearshift. I can't begin to describe how much better this is, even under full bore acceleration.
For me, the handling improvements are the main selling point. A standard MK4 that feels significantly more planted and less understeery - just from engine mounts? I'd buy that for a dollar!
It's all about doing more with what you've got
With increased power they become even more important.
Hmmmm, I'm warming to them but I'm still not sure. What other options do I have?
You can put poly inserts in the dogbone, which is nice and cheap, but that doesn't stop the engine shunting about during cornering. You've still got the standard LH and RH mounts.
Then there are poly mounts and DLI technik mounts (the aforementioned spring with wire wool inside) but these are even more money than VT and you really need to hang up your concerns about NVH if you choose those.
You could try brand new standard mounts, but these will be blancmangey and useless again within 3 months.
You could try filling all the voids in the standard mounts with poly urethane. The way the standard mounts work is all the little holes and voids provide a nice cushion when you're cruising, but when you nail the gas, the mounts compress and effectively become solid rubber, albeit soft rubber.
You can buy liquid poly kits to fill all these voids and holes, but the results can be hit and miss and it's only worth doing on brand new or VGC mounts.
So in short, if you don't want any increase in NVH at all, stick to the standard mounts and live with the horrible gear shift, horrible shunting, engine rocking at idle, wheel hop and flopping about in corners.
And if you're a keen driver who can live with a slight loss of refinement, get the Vibras
Hope that helps!
· Eats Kitty Litter
Great write up for a very good piece of kit. I have these mounts on both my R32 and Audi A3. They are by no means cheap but definitely very very good.
Great write up!
You've definitely got me sold
noticed a hell of a lot of movement in my engine under acceleration the other day and it looks to be the Gearbox side mount, probably moving around 50mm on acceleration
Do these need Torquing up or are they just torqued to F***ing tight with a power bar?
I'm touched you guys actually read all that! You must have been bored at work
Smitty, I just leaned on the bolts! I couldn't find the torque figure, but as they are M14s, it'll be around the 80lbft mark.
For the driver's side mount, you need to pack out the 2 bolts with about 8mm worth of washers (not included). I don't think Vibra are aware the stock bolts bottom out in the engine bracket (their mount is thinner, being steel instead of ally) but I will mention it to them.
The two side mounts do the bulk of the handling improvements. The dogbone just takes care of the fore / aft movement and VT's is an interesting design. They measured 20mm of movement in a new standard mount (old worn ones move considerably more). Their dogbone insert kit reduces that to 5mm in the firmest setting (they're adjustable with supplied shims), but without the harshness of hard poly or metal.
I also noticed the OEM driver's side mount is some kind of trick fluid filled thing. No wonder it's expensive! It doesn't work though,lol!
· South East Organiser
I need new gearbox one as mine is pretty worn out. good write up.
Slight correction on the side mounts, the bolts are M12s (not M14s) and I torqued them to 70lbft, but please do look up the official torque figure if in doubt.
I emailed Vibratechnics about the driver's side mount needing spacer washers under the bolts. No response so far, but all you need is a bunch of M12 packing washers from B&Q.
Hope you guys like them. As I say, the passenger side mount is the one that causes the increase in noise and vibration, but it's nowhere near as bad as poly. Don't be alarmed if you hear more gearbox noises when manoeuvring the car slowly. It's normal with firmer mounts on the MK4.
The Vibratechnics dogbone insert on it's own with the 2 stock side mounts is good too. I tried that first out of curiosity. Loads better than the Powerflex diesel one I had in there before.
CorradoR32 said:
Slight correction on the side mounts, the bolts are M12s (not M14s) and I torqued them to 70lbft, but please do look up the official torque figure if in doubt. I emailed Vibratechnics about the driver's side mount needing spacer washers under the bolts. No response so far, but all you need is a bunch of M12 packing washers from B&Q. Hope you guys like them. As I say, the passenger side mount is the one that causes the increase in noise and vibration, but it's nowhere near as bad as poly. Don't be alarmed if you hear more gearbox noises when manoeuvring the car slowly. It's normal with firmer mounts on the MK4. The Vibratechnics dogbone insert on it's own with the 2 stock side mounts is good too. I tried that first out of curiosity. Loads better than the Powerflex diesel one I had in there before.
hey bud I realise this post is nearly a year old, anyway I fitted both left & right mounts last week & discovered on the right hand side as you said, they require spacers, but what I also discovered is that the spacers need to be inserted between the bracket of the engine & that of the mount, because the cutout notch on the vibra-technics mount isn't as deep as on the OEM, therefore the flat mating surfaces of the mount don't sit flush on the bracket to the engine.
I replaced the dogbone bushes about a year ago but recently I been hearing manifolds ***** on the subframe and have been looking for a sensible alternative to the stock mounts. Many thanks Kevin for taking the time for an accurate appraisal & will be getting a set of these ordered up end of next month.
Just one thing I need to get clear - The spacer issue with the drivers side mount.
Corrado32 states that the OEM fasteners ground out in the engine based part of the drivers side OEM mount as the replacement vibratechnics thickness is less than the stock inner wing mount - sound simples.
Andy4Motion is saying that that the locating 'V' key depths are incorrect between items 5 & 12 preventing the lower mount from pulling up flush on both faces to the upper mount when tightening the fasteners? Sounds like you may have the wrong Vibratechnics PN and may be worth worth checking?
I just want to add to this review after having the engine mounts (Fast Road spec) fitted to my car. I also had the 034 Motorsports Dog Bone fitted as opposed to the VT one. I can tell that to all intents and purposes there was no difference in NVH. My wife couldn't notice anything had changed, and only after actively looking for a sound or vibration could I actually feel any difference.
I bought them from Awesome Gti and they fitted them for me too. Hassan there did me deal and I am so glad I had them fitted. The comments above about the better gearshifts and better handling are totally true and you can feel the performance benefit.
If you are going for more power now or in the future, get these mounts without hesitation.
If you don't mind me asking how much did these cost? as I'll be going to awesome to have these done at some point.
1 - 20 of 28 Posts
