Hi All
I have fitted the later G2 xenons, but drivers side has a problem...after fixing the ballast cover i noticed the reflector was loose inside the housing. the internal retaining clip had broken, so i thought simple...put a grub screw in to hold it inplace..til i plugged it in and realised the reflector would not move with the levelling motor!...scouring the web produced a video of a chap with the xenons apart and the bit i screwed solid should have a black plastic four way pivot piece to allow movement. With my repair the light is about half an inch too low and i have no way of adjusting it!!!
dont suppose anyone has a bare drivers side xenon headlight casing/reflector i can swap my parts into?
Help!
and thanks
Help!
and thanks
