1 - 4 of 4 Posts
Hi all,
Just wanted to ask a question. Does anybody know where that wire/sensor on the intake manifold is for? I mean the one on the right side of the intake manifold with the thin wire coming out.
From that sensor/plug there is a thin wire that runs towards the back of the engine but when it splits up I cant really follow it to see where it goes to.
If I want to install a boostgauge is it correct I need to add a sensor to the intake manifold?
Sorry am a nab when it comes to electronics/wiring.
Yes that's your temp sensor. One wire will go to ground and the other to a wire that use to be wired to your maf.
To add boost gauge just tee off of a pipe from manifold before any 1 way valves.
Thank you for the info!
1 - 4 of 4 Posts
