This seems to be a mine field all over the net from what i read! But anyway... As you might know im in the middle of a R32 conversion into my golf. Im building it up using the 02M box. I know there is slight differences between R32 and 4mo flywheel butbis the slave the same if not whatbone do i go for?
As i mentioned 02M box R32 enging and im using a Spec clutch and solid flywheel
Thanks Scott!
Thanks Scott!
