i have some moderate/severe swirling on the car and it really annoys me when the sun is out! i am a bit of a newbie with this detailing stuff...i have been looking at some polishes which are 'made' for the job of removing swirling and they warn of them being abrasive. i understand that to remove the swirls, some abrasion has to be used, but will the paint need protecting with another product after this?
i was wondering if anyone could recommend a product that they found good for this...and wont blow the bank?
cheers,
chris!
Yes, it will need to be protected with a sealant and/or wax.
The choice often depends on what colour car you have, as some work better on certain colours.
Removing swirls by hand is going to be very hard, it can be done but you wont achieve the results that you can with a machine polisher and you'll end up with very sore arms! Machine polishing isn't something to be entered into lightly either, if you're using the wrong equipment/polishes or a combination of that and bad technique you run the risk of seriously screwing your paint. I've seen it done before to owners of show cars at shows :S My advice would be to sign up to a detailing forum and see if there's anyone in or around your area who can show you what to do. I did this recently through a detailing day and i'm much happier about what i can achieve and how to achieve it. As i'm more cautious i'd probably go with a Megs G220 rather than a rotary that can be a bit more hardcore!
Blacks an awesome colour if you have the patience to give it the work it requires!
