1 - 20 of 34 Posts
Guys,
Need some advice, as I have to change my wheels to fit the above calipers I need some ideas as to what wheels will clear that don't costs the earth.
Preferably after advice from guys who have them fitted rather than here say.
Was looking at a set of OZ superleggeras in an ET35 fitment, would these need spacers still?
Cheers.
The Super's tend to have quote a lot of space behind the spokes. Its difficult to say without actually testing the wheel upto the hub!
I'm running standard wheels with 15mm spacers & there's not alot of room to play with!
I'm sure an old member "Rory" was running supers with Porsche callipers unsure on spacers tho! Check his build thread its a silver mk4 r ill try n get u a link
Just read his forsale thread & it says 10mm spacers front so I would guess
10mm spacers & supers is fine
yeh I own the car now and he did run 10mm spacers but he also told me he had rubbing issues. It may of been due to running the car quite low I dont know. I can double check the offset as I still have the alloys on the car but different suspension not calipers. Also I think they might of been cayenne calipers.
I think cayenne calipers are bigger than 996tt 1s but I could be wrong!
I would of said 15mm to be on the safe side
Sure my wheels are et35, 16mm spacers give me the absolute minimum clearance for my 996t calipers, oz wheels may need a lil less, depends on the shape of the back of the spokes I suppose
I've got cayenne calipers which I believe are bigger, I've got 10mm spacers with et35 blq replicas and they clear fine. Do get some rubbing on the arch though
You need to bring the ET on 6pots down to ET23
I tried my supers ET35 on 6pots and needed crazy amount of spacing so i gave up.
Its not the offset you need to worry about, the inside of the super is fairly flat as the aristo is almost bowing out.
Not an entirely helpful response but im sure Lucifer ran a 10mm spacer on his setup
South East Organiser
My bbs ck wheels have an inch of clearance all round my stock calipers. If that is any sort of help....
Sent from my blower by a cat
Bradley Hall porsche breakers near Manchester Wigan.
Had three sets of lobster claws with 9.5 rears.
First set was 500 other 2 where 600
still got a set on my car
1 - 20 of 34 Posts
