1 - 12 of 12 Posts
I was just pondering swapping my rear discs with the next pad change.
I was sniffing on eurocarparts.com and it lists 4 different Pagid discs for my 2007 Mk5.
104441258 £32
104441278 £35
104441518 £38
104441268 £50 (out of stock)
They have subtly different weights, diammetres and thichnesses.
Which ones ?
Rich
Think it's something like R32OC25 to get 25% off but sure someone will be along to confirm!
That's correct "R32OC25" is the 25% discount code.
Just double check their promotions on the homepage and that there isn't one with a higher discount at the time.
Also the R32OC discount cannot be used in conjunction with any other promotion or discount.
There should be a "PR Number" stated on the ECP webpage for each brake disc / pads - which you can then match up with the codes in your handbook under "Vehicle data" eg 1LM.
Changed my discs & pads myself last weekend but went to TPS instead.
1 - 12 of 12 Posts
