1 - 11 of 11 Posts
Alright lets see, does anyone know if the carbonio on my Octy VRS will fit the R32 iv? I have looked at the awesome website and they quote a different order number between the 2. Surely there can't be that much difference? If it will swap then i don't have to shell out cash and justify to the GF the cash outlay for another one.
Any help much apprecited.
Mike
I haven't seen the RS one, but the pipe etc is probably the same. It'll be to mounting points that'll be different.
As for mounts they should be the same being the same basic platfor etc. It all looks very similar.
Pic of the VRS one.
http://
Is the MAF diameter of the Skoda the same as the R? This could be the only difference. It looks like a golf underbonnet. Try fitting it and see, for all the time it'll take.
i would say its the reducer size from the maf to the carbon pipe that is the only difference. then maybe just get a reducer from some where
IIRC the MAF diameter is different for the 1.8t engine. It would fit with a reducer but would not provide the correct air flow for the v6.
The only difference is as stated above the rubber connector that runs between the MAF and the carbon pipe, it is slightly smaller in diameter. I purchased one off a friend and managed to stretch it over without much trouble. Should be fine.
Someone on here could measure round the diameter of their carbonio pipe and you could see if there's a difference.
Can't see there being much difference in air flow i would expect the filter and carbon pipe to be the same just as said maybe a differenct coupler for the MAF. Sod it i'm going to fit it when i get home and see what happens. Should i expect a great noise difference when i do it??
1 - 11 of 11 Posts
