My front windscreen washers have stopped working, the wipers move like there is fluid being sprayed but nothing comes out and I don't hear the washer pump, but if I spray the rear it works and I hear the washer pump, I assume there is only one washer pump, any idea what the issue could be ?
Thanks for the video but the pump works when I use the rear wiper and nothing happens when I use the front wiper.
My guess would be the relay or the connections it.
Front and rear operate off the same pump, it changes direction between front and rear., and they operate off the same fuse, as far as I know.
Switch is obviously OK as the wipers operate when you pull on it.
Do you know where the Relay is ?
Have a look in this document, although not sure whether it's applicable to the R32
Thanks, the document was perfect, I swapped the relays around and they all work so it can't be them, I did note that the headlight washer also does not work, I'm thinking if the headlight pump is broken then maybe it has some effect on the front washer...
