1 - 8 of 8 Posts
The glass on the drivers side came off in my hand but I managed to glue it back. But when I started to readjust it with the stick on the door card it would move the passenger side mirror at the same time but if I flicked it to that side it would only do that one mirror. Any reason why this is happening?
I thought it done this normally, so for example if you adjust the drivers mirror up or down it matched the passenger side for the same height ? but in and out adjustment is per side?
Maybe im wrong but mine does the same thing .................
Wez
As above it's normal.
On the MK5 with highline it is a setting that can be ticked / unticked to remove the relationship.
It's to make it easier to set up when changing between drivers
I have this on a MK4 tho ?
Wez
Yes, it's on the MK4 too but I know Raiden has a MK5.
Never having had a MK4, I couldn't be sure it was selectable via the highline on the MK4, so just made reference to MK5, which I know about.
I know it's standard on the MK4 and selectable using VCDS.
Okay thanks buddy
You are a man with knowledge
Wez
1 - 8 of 8 Posts
