1 - 20 of 47 Posts
Hello Guys,
I am a R32 owner from the Netherlands :)
This summer i fitted my MK5 R32 (5-door) with 19inch OEM Talladega wheels.
At first wanted to keep the suspension stock, but recently i changed my mind....
After reading some posts here, i think of buying H&R sport springs.
Saw som pictures here in i think it is a nice look (not too much)
My questions:
How much CM lowering should i buy ?
Are there people here with 19 inch Talladega's fitted with H&R shocks ?
Hope there are some guys with puictures
· Administrator
HansR32 said:
Can i use 30mm without rubbing ?
Tires are 235-35-19
With 35 profile I would say you would be ok,
But not 100% sure, the only ones I have seen on 19's lowered have coil overs so are adjusted accordingly
If it was me (as I like low) I would risk it but if you are a bit more cautious go for 20mm
H&R dont do 30mm drop do they MIQ ? i'm on 182 omanyts and woudlnt mind dropping it 30 instead of 20mm
Searching this site, i saw there are am lot of guys using H&R springs.
I wonder what they are using without rubbing...
What choise has H&R in springs ?
IMO what is 35 profile ?
My car is on Continental Sportcontact 3
235-35-19
· Administrator
235-35-19
35 is your tyre depth from the rim to top of tyre
· Administrator
They do apex ones
Look at this on eBay:
VW Golf Mk 5 R32 04- APEX LOWERING SPRING KIT
http://bit.ly/1cDQH1N
235-35-19
35 profile is the relationship (aspect ratio) between the height of the tyre sidewall and the tyre tread width.
35 means that the sidewall is 35% the width of the tyre tread. As your tyre is 235mm wide, the side wall is around 82.25mm in size.
The profile is outlined in the tyre size
235/35x19
Width (mm)/profile (%) x diameter (Inches)
They do apex ones
As i decided 20mm by H&R wasnt going to be low enough for me to take out the gap, i was thinking Apex but heard bad reviews both on this site when using google search and others, which kinda put me off.
· Cutting Edge Member
Im after putting some H&R springs on mine but worried about rubbing over bumps and dips in the road as i drive a lot down country lanes
My Et 42 tyres 225/40r/18
18" x 8.0J 5-112 ET42
· Premium Member
fernr32 said:
Im after putting some H&R springs on mine but worried about rubbing over bumps and dips in the road as i drive a lot down country lanes My Et 42 tyres 225/40r/18
18" x 8.0J 5-112 ET42 18" x 8.0J 5-112 ET42 18" x 8.0J 5-112 ET42
You won't. Unless you have a car full of fat chicks :)
1 - 20 of 47 Posts
