1 - 6 of 6 Posts
Hi there,
I have a weird problem with my mk4, where if I hold the pedal still and, say, rev to 1500 rpm, the revs go up, then drop, then go up a little more to, say, 1200 rpm. Above 2000rpm is seems fine.
I have read a few threads where people are noticing the same, but this is always in conjunction with other failures. I have vagcom, and have no fault codes, and have put a bosch MAF on over a year back - is there anything specific I should be searching/logging when I do a scan?
Its also pretty jerky in low gears, and as you accelerate the power delivery doesn't seem very smooth.
Anyone else have this issue? I suspect an air leak, but im not sure where to look!
Could be a number of reasons (sadly)...
- Dirty throttle body
- Failing MAF (although readings from the maf would show this up)
- Vacuum pipe split somewhere
- Coilpack breaking down
Is the car running the standard map?
Had the same problem on the 1.8t. Disconnect the MAF and see if runs ok.
MAF was the issue and had not come up on VAGCOM.
A bit more investigation suggests maf is good, and block 32 reading for 2nd bank (long term) is 3.2%, with the rest close to zero.
I think that it's ok regarding an air leak given the trim figures, and a poke around suggests no obvious source for a leak.
Would the air flap at the front (I have forgotten it's name) cause any hold back when changing up through the gears do you think?
1 - 6 of 6 Posts
