R32 Timing Chain checking - Performance and Technical - R32OC | VW Golf R32, Golf R and other .:R Vehicle Owners Club.
4 replies to this topic
G60Dub
G60Dub
  • 782 posts
  • LocationAberdeenshire
FAQ? Timing Chain Values
Just want to post up the following top help assist in any timing chain queries. I do a lot of trawling on the German VAG forums and finally got around to translating the information below that will no doubt be helpful to many.
The information below has been part translated in google translate and then finished/validated by my Mrs. As such it is provided here as-is.
To test the timing chains often only the values in VCDS blocks 208 & 209 are deemed relevant. However, this is misleading for correct diagnosis of guide/chain wear and possibly other components.
Therefore, ALWAYS reference blocks 90 & 91 when checking blocks 208 & 209. This then basically references the cam to crank timing via the intermediate shaft by correlation of the crank sensor to the cam phase sensors.
• The timing chains values in blocks 90,91, 208 & 209 must always be read when the engine is warm. Measurements must always be taken at a minimum of about 60°C operating/oil temperature or higher, otherwise the cam adjustment is not yet fully active.
• Measurements are always taken at idle
Valid for both MK4 and MK5 R32:
• Blocks 208 & 209 should be as close as possible to 0°, the spread should not exceed 3°. The absolute wear limit is 8° spread whether + or minus. If the spread is well above 3° but under the limit, then chain & guide replacement should be considered.
Cross examination of the intermediate shaft values of blocks 90 & 91:
Golf 4 R32 only (intake adjustment range 52°/exhaust adjustment range 22°):
• Block 90 (exhaust) set-point is 0°, no matter the values in blocks 208 & 209, at a duty ratio of about 15.3%. The actual value should not be more than 0.5° out (Valid for both OEM & aftermarket cams). If the values are way off from 0° the timing chain may be mistimed or skipped. Around 11.25° deviation corresponds to a skip of 1 tooth.
• Block 91 (intake) set-point is 22° between idle to about 1200RPM, no matter what the values read in blocks 208 & 209, at a duty ratio of about 15.3%.
The actual value should not be more than 0.5° out (valid for both OEM & aftermarket cams). If the value is not close to 22° the timing chain may be mistimed or skipped. Around 11.25 ° deviation corresponds to a skip of 1 tooth.
Golf 5 R32 & Audi BUB only (intake adjustment range 52°/exhaust adjustment range 42°):
• For both blocks 90 & 91 the set-point value at idle is 0°, no matter what the values in blocks 208 & 209, at a duty ratio of about 15.3%.
The actual value should not be more than 0.5 ° (Valid for both OEM & aftermarket cams).
You can for whatever reason also check the cam/crank timing manually by setting the timing to TDC via the timing mark on the crank pulley then pulling the cam phase sensors and checking where the centre parts of the cam variators sit with respect to the sensor hole. I’ll dig out a pic from somewhere and annotate it as it’s quite obvious once you see it. I guess this won’t be quite as accurate as checking blocks 90,91, 208 and 209 in VCDS but might prove helpful nonetheless.
Again the info is provided as is as I’ve only translated it and as such I’ll reference the original page once I figure out its’ address.
Additional for consideration:
As is known faulty cam phase sensors cause spurious readings. However a surprising point to note is that high values are not always indicative of worn guides or a stretched chain! There have been instances in Germany whereby poor service intervals (Longlife) has gummed up the cam variators/VVT assemblies/solenoids resulting in high values that’s clearly appeared to be worn chains but after several oil flushes and filter changes returned to almost perfect ‘out the factory’ values. There appears to be some correlation between the intercam timing spread and the intermediate shaft values that points to this; if I can find the original page I’ll save it off and translate it. As best as I can tell a good way to help in diagnosing if the chains truly require replacing is to also log the requested vs actual cam timing in VCDS. One of the symptoms of sluggish cam timing is mild bucking/hesitancy similar to a faulty MAF. If the actual values values are slow to match the requested values then his points to a gummed up VVT system or the inlet gauze possibly being blocked.
The snapped chain syndrome on the early MK4s was attributed to the Sachs stamping weakening the chain links and also related to chemical corrosion caused by the extended Longlife service intervals (A topic for a future post when I get around to translating it). Chain stretch was mainly attributed to buggy/poor implementation (in early software revisions) of the VVT causing cam kickback and resonance effects on the chains at particular RPMs; this also may attribute to guide wear (but the likely main culprit was still the extended Longlife -what an oxymoron- service intervals) and (I've not fully translated this yet) possibly linked to faulty pressure relief valves in some oil pumps although that again could simply be caused by the extended Longlife service intervals.
Edited by G60Dub, 08 September 2016 - 06:41 PM.
  • Palf, Antoinemic and AllieOref like this
Bora R32 More-Commotion
kingswood
kingswood
  • 946 posts
  • LocationHull
in laymens?! lol
great work on translation.
read a similar thread the other day - in a link about chains- where a kid was pretty much saying the same, that blocks 208/9 readings dont indicate wear.
G60Dub
G60Dub
  • 782 posts
In laymans - A lot of people, including myself, have jumped on the chain stretch bandwagon fearing the worst when in fact the general opinion or fear is much worse than the reality. In probably many cases gummed up internals or faulty cam phasers can be the culprit and should be ruled out before proceeding to fear the worst. There are still plenty cases of chain stretch in newer vehicles but the cause appears mostly related to extended service intervals.
If you buy an R then get the chain values checked and make a note and then periodically check them - If they stay constant then there is not much to worry about. Just make sure to stay on top of the oil/filter changes.
Edited by G60Dub, 09 September 2016 - 08:15 AM.
woyasr32
woyasr32
  • 3 posts
Hi
What you think about my VCDS test for measuring blocks. I'm attached picture with results. I'm so sorry for quality picture.
Edited by woyasr32, 14 June 2017 - 07:38 PM.
Jamesmm86
Jamesmm86
  • 1 posts
Hi i don't have an R32 but i do have a 2.8 v6 4mo with the BDE engine which i have read is the most similar you will get to the 3.2.
So i have come to you R owners for a bit of advice
Now my car makes very little noise cold but once hot it makes a strange sound at idle and slow speeds
I have asked my vag specialists to check the chains and said that they can't hear anything untoward and that the vids shows no issues.
Here is a link to a couple of videos of the sounds, any help and advice welcome, thanks very much.
hot idle   watch
1 user(s) are reading this topic
0 members, 1 guests, 0 anonymous users
