Turbo camshafts - Forced Induction - R32OC | VW Golf R32, Golf R and other .:R Vehicle Owners Club.
Turbo camshafts
17 replies to this topic
Lionborg
Lionborg
  • 425 posts
So i thought i would start this discussion on cams, i haven't been able to really find the answers anywhere so ill just post the questions here.
Ive been lurking around for cams, the past months, i dont really need them but just curious.
How much does it actually benefit our engine, when turbo'ed?
How much will the different cams expand the RPM range? For example the Schrick 272/264 kit.
Should a turbo R have symmetric profiles or asymmetric profiles? and why?
I know theres a lot more air coming thru when the lift gets bigger, but all the "off the shelf" cams seem to have the same lift, 11mm, except the cams with symmetric profiles, for example the 272/272 which only has 10,8mm lift.
Does anyone have a dyno sheet with before/after cams? if so please share
Finally, what is the limit of oem cams? :)
Edited by Lionborg, 04 May 2017 - 06:29 PM.
  • ToerryLox, Doro lDor and Mikefoelf like this
mattdub
mattdub
  • 1279 posts
  • LocationBirmingham
CTS turbo seem to do the biggest range of cams I've seen. Know a few guys in the states running 280/264 or 272/264, but always seem to be a symmetric once you go above the 264's.
Sure one guy was running 272/272 and said they performed great :)
7b3788_fa526ad09a354d58b8937ea5800aa003~
- ROTREX KITS NOW AVAILABLE FOR BOTH C30 AND C38 MK 4 PLATFORMS (MK 5 IN DEVELOPMENT!)
- HEAD SPACER KITS FOR 2.8/2.9/3.2 ENGINES
- CUSTOM FRONT CRASH BAR SOLUTIONS WITH BIG COOLERS
NUKE PERFORMANCE DEALER - R32OC MEMBERS DISCOUNT
CONTACT - [email protected]
Lionborg
Lionborg
  • 425 posts
CTS sell Schrick cams.
Id really like to see a dyno sheet of a turbo (or SC) R32 with 280/264 cams.
Lucifer
Lucifer
    Eats Kitty Litter
  • 7307 posts
  • LocationCullompton Devon
Bar-Tek are much cheaper for Schrick cams then CTS
Lionborg
Lionborg
  • 425 posts
Indeed they are, but they only have 268/264 on the website.
Lucifer
Lucifer
    Eats Kitty Litter
  • 7307 posts
Bar-tek can get any camshafts size you want. I have bought 268/264 and 268/272 from him. Just message them what you want.
Matty.vrt
Matty.vrt
  • 9 posts
Looking at upgrading my cams Lucifer. What gains did you notice and at what rpm range?
Lionborg
Lionborg
  • 425 posts
Double post
Edited by Lionborg, 07 February 2018 - 12:54 AM.
Lionborg
Lionborg
  • 425 posts
To update this:
I eventually ended up buying the Schrick 280/280 cams, and they really did wonders! Much more torque, starting from 3000rpm and all the way out, turbo actually spool a little faster now.
With stock cams, power peaked at 6700rpm and with the 280/280 cams I rev to 7200 and still haven’t hit peak power.
Unfortunately I had too much backpressure so couldn’t go past 600ish HP, but these are the numbers, only the cams and mapping was changed:
Stock cams: 607hp 727nm
280/280 cams: 607hp 790nm
I think I have now solved the issue with backpressure, so this summer I will turn up boost and rev a little more, to really see the potential with these cams.
  • raguturbo and Lucifer like this
Toffs
Toffs
    .:R32OC Parking Attendant
  • 4023 posts
Interesting to hear about the improvements with cams on a Turbo'd engine, well done for taking the plunge !
Toffs
  • franko180 likes this
 0-60: 3.7sec                                            BHP: 450-500                        Torque: 700+ Nm                              Fun: Incalculable
gallery_2294_1980_2835.jpg gallery_2294_1980_8853.png gallery_2294_1980_12960.jpg gallery_2294_1980_20971.jpg
Matty.vrt
Matty.vrt
  • 9 posts
I have been talking to catcams about some turbo specific cams. Planning on pushing the stock ones as far as I can before I switch, then I will post some before and after graphs.
  • IMG likes this
Lionborg
Lionborg
  • 425 posts
Stock cams can be pushed pretty far, I’ve heard of more than 700hp. But they will limit ft/lbs . I gained more than 60NM (45ft/lbs) at the same boost just by upgrading cams.
Matty.vrt
Matty.vrt
  • 9 posts
Here is my graph.
Stock cams
8:1 compression
20 psi
GTX4202R 1.15 turbine
Would be interesting to see how your map differs with your cams.
Attached File  6FC361AF-DEAC-4D23-A03B-093AE7B48513.jpeg   66.73KB   3 downloads
Edited by Matty.vrt, 25 March 2018 - 04:23 PM.
  • viw28 likes this
viw28
viw28
  • 13 posts
To update this:
Did you have to machine the piston crown at all for these to work? What pistons are you running btw?
Thanks for starting this thread, been wondering what’s best to use for a while now, just not done anything about it yet.
Lionborg
Lionborg
  • 425 posts
I didn’t machine the pistons, as I run stock pistons with a 4mm head spacer, so plenty of space down there, but unsure how much clearance there is with low comp pistons and a normal head gasket.
#16
viw28
viw28
  • 13 posts
Yeah, spacer would certainly help in that case!
#17
Lionborg
Lionborg
  • 425 posts
There’s plenty of Americans running the 272/272 cams with JE pistons, so I’ll guess that combo works without issues. But I’ve never heard of anyone running the 280/280 with “off the shelf forged pistons”. Maybe I’ll measure the clearance some day, but currently I’m on a mission, push the stock pistons past 700hp.
#18
Matty.vrt
Matty.vrt
  • 9 posts
Sure they is a French guy running 1000+ on standard pistons in a Audi 80 Quattro coupe (maybe S2)
