Turbo dyno thread. - Forced Induction - R32OC | VW Golf R32, Golf R and other .:R Vehicle Owners Club.
Turbo dyno thread.
18 replies to this topic
Lionborg
Lionborg
  • 425 posts
So the idea is you post your dyno graph AND spec list, for others to see how different mods, turbos, exhaust, cams etc affect HP, Torque, spool and so on.
I’ll start since I have done plenty mods and had a few different setups. I’ll make a model you just copy and apply your own specs.
  • DubNurd, iooroiidvd, ClintonB and 2 others like this
Lionborg
Lionborg
  • 425 posts
Turbo and trim: Turbonetics T04B T4 .69
Turbo manifold: Eip ram horn
Wastegate: Tial F38
Exhaust: 3” down pipe, 2,5” milltek
Catalytic converters?: No
Intercooler: cheap 500hp core.
Intake manifold: stock
Cams: stock
Engine: stock engine with 3mm headspacer.
Boost 0,8 bar 12 psi
Result 406hp 548nm
Edited by Lionborg, 21 March 2018 - 11:34 AM.
  • iooroiidvd likes this
Lionborg
Lionborg
  • 425 posts
Turbo and trim: Garrett GT3582R T4 .82
Turbo manifold: Pagparts cast manifold
Wastegate: Tial F38
Exhaust: 3” down pipe, 3” Eip comp exhaust
Intake manifold: eBay cast manifold
Cams: stock
Boost: 1,2 bar 18psi
Result 468hp 565nm
Edited by Lionborg, 21 March 2018 - 11:35 AM.
Lionborg
Lionborg
  • 425 posts
Turbo and trim: Garrett GTX3582R T4 1.06
Wastegate: Tial F38
Cams: stock
Engine: forged H-beam rods, stock pistons and 4mm headspacer
Boost: 1,7 bar 25 psi
Result 569hp 736nm
Note the only thing that changes here from the one before is turbo is a GTX and has a 1.06 housing instead of the .82. That plus the forged rods allowed lots more boost which really woke op that engine.
Lionborg
Lionborg
  • 425 posts
Turbo and trim: Garrett GTX3584RS V-band 1.21
Turbo manifold: Turbular SS manifold
Wastegate: Turbosmart Hypergate 45mm
Exhaust: 3,5” downpipe and 3,5” handmade exhaust.
Intercooler: Threadstone 1000hp Core
Intake manifold: P-motorsport manifold
Cams: Schrick 280/280 cams
Engine: Forged H-beam rods, stock pistons and a 4mm headspacer
Result 607hp 780nm
Edited by Lionborg, 21 March 2018 - 11:36 AM.
Matty.vrt
Matty.vrt
  • 9 posts
Turbo and trim: Garrett GTX4202 Divided T4 1.15
Wastegate: Twin 38mm Tial MVS
Exhaust: 4” downpipe and twin 3” handmade exhaust.
Intercooler: Air to Water 3.5” inlet/outlet
Intake manifold: P-motorsport manifold Duel Plenum
Cams: Standard
Engine: Forged H-beam rods, JE 8.5:1 pistons, crank
Girdle, NG Motorsports porter head & supertech springs/retainers
Boost: 1,4 bar 20 psi
Result 555bhp 430ft lbsAttached File  0F49F1CE-2D22-424C-8763-96B9406425E1.jpeg   66.73KB   15 downloads
Lionborg
Lionborg
  • 425 posts
So here’s a new one from me. Actually only changed the exhaust housing from V-band 1.21 to a T4 twin scroll 1.06. Manifold was made to a twin scroll so removed the “adapter” I had made. The result is 800rpm faster spool and another 65hp. Haven’t hit the magic 700 yet, but I’m working on it.
Turbo and trim: Garrett GTX3584RS T4 twinscroll 1.06
Wastegate: 2x Turbosmart Hypergate 45mm
Boost: 1,8 bar 26 psi
Result 671hp 794nm (583lbs)
Edited by Lionborg, 08 August 2018 - 02:02 AM.
  • franko180 and iooroiidvd like this
Lucifer
Lucifer
    Eats Kitty Litter
  • 7307 posts
  • LocationCullompton Devon
Interesting to see you made more power with a smaller A/R .
Lionborg
Lionborg
  • 425 posts
The problem last year was backpressure in the turbo manifold, and the T4 twin scroll housing solved that problem, probably because I could ditch the v-band-T4 adapter. Removing a restriction would be the reason for gaining 65hp, and twin scroll combined with a smaller A/R gave me the 800rpm spool time
Lionborg
Lionborg
  • 425 posts
Mike don’t you have a dyno sheet from your car with the GTX4088R on? Id love to see how it spools and delivers torque
Edited by Lionborg, 08 August 2018 - 10:25 PM.
Lionborg
Lionborg
  • 425 posts
So I might as well update this.
Late August I had my car in the dyno again, I raised the fuel pressure and wanted to give it more boost. Here in Denmark we recently got 100 octane pump fuel which I believed would help me break into the 700hp mark.
First run it produced amazing 721hp at 27psi with super rich mixture, about 10 afr. So we turned boost down to 23psi and started working on the fuel map to get afr 11.5. But we only got to 4th pull when the engine started sounding strange, so we stopped and got the car transported home. Then i found out it had broken the crankshaft...
Boost: 1,65 bar 23psi
Result 709hp 877nm
Here is the dyno where it snapped the crank. Next year I’ll be going R30 with DP pistons and 2.8 crank
  • 495 posts
Result 709hp 877nm
Some really good figures there. Shame the crank stopped play, was interested to see how far you’d get with the gtx3584r. Onwards and upwards.
Lionborg
Lionborg
  • 425 posts
The plan is to build a bullitproof engine and push the GTX3584RS as far as it goes, but who knows, maybe there will be a bigger turbo on next year. I’ll make no promises :)
  • IMG likes this
Tj0785
Tj0785
  • 386 posts
Result 709hp 877nm
Do you have a part number for the forged crank ?
MOOMO96
MOOMO96
  • 25 posts
700hp really? I am only 6psi and  and I think its enough for me ... anyway its amazing bro try to use Q16 next time for safe after you fix it
#16
Lionborg
Lionborg
  • 425 posts
We don’t have Q16 here in Denmark, and as this is a street car ill stick with pump fuel. I don’t need safety, I need stronger internals :D
#17
MOOMO96
MOOMO96
  • 25 posts
Edited by MOOMO96, 16 December 2019 - 09:02 PM.
#18
MOOMO96
MOOMO96
  • 25 posts
#19
raguturbo
raguturbo
  • 5 posts
Lionborg, any updates on new set up? What's the reason for going down in stroke better ration in bottom end or do you feel the w.8 crank is stronger? Also have you been on a stock trans this whole time?
