Rotrex supercharger - Forced Induction - R32OC | VW Golf R32, Golf R and other .:R Vehicle Owners Club.
Rotrex supercharger
2 replies to this topic
Marky32
Marky32
  • 407 posts
Anyone running rortrex c30-94 came across any slight oil leak from bottom of charger seal if so does it affect the working of it .
Andy
Andy
  • 3484 posts
think Dent Reform is on this set up
mattdub
mattdub
  • 1279 posts
  • LocationBirmingham
Best advice is take the unit back to the supplier and run it through the warranty process.
If its an internal seal (theres 2) and its failed rotrex will swap the unit out gladly, if its self inflicted then you may have to source another of just keep a good level of oil in it.
Definitely worth checking both inlet/outlet to make sure they arent weeping, if its actually leaking from the casing around the planetary rollers then its passing through the seal. 2 option remove the charger and make all 2 m6 allen key bolts are tight (2 pull the full casing together).
What can happen if the pulley gets rotated the wrong way during fitting is the seal around the bearing that holts the pulley shaft can leak, again get it stripped off and back to rotrex.
7b3788_fa526ad09a354d58b8937ea5800aa003~
- ROTREX KITS NOW AVAILABLE FOR BOTH C30 AND C38 MK 4 PLATFORMS (MK 5 IN DEVELOPMENT!)
- HEAD SPACER KITS FOR 2.8/2.9/3.2 ENGINES
- CUSTOM FRONT CRASH BAR SOLUTIONS WITH BIG COOLERS
NUKE PERFORMANCE DEALER - R32OC MEMBERS DISCOUNT
CONTACT - [email protected]
