Headlining re-trim Mk4 - Interior and Exterior - R32OC | VW Golf R32, Golf R and other .:R Vehicle Owners Club.
6 replies to this topic
Krankenshafter
Krankenshafter
  • 99 posts
Need a bit of advice: Headlining/ pillar covers etc are manky and need sorting. I want OEM colour, not black. Can anyone recommend me a trimmer in the SE area? Will re- trimming be significantly cheaper than new replacement?
Cheers.
Krankenshafter
Krankenshafter
  • 99 posts
Been looking into this. The rear upper trim at the back of the headlining is NLA. All the other parts can be purchased. But its not cheap. You are looking at about 1200 plus vat for a sunroof model 2 door. A visit to a few trimmers is next.
Krankenshafter
Krankenshafter
  • 99 posts
Update - a year later.
I had it re-trimmed last winter Parted with 500 quid. It looked good, but extra bulk where the material was wrapped over the hard panels made it a bastard to install. upper trim at the tailgate was especially tricky. The clips just wouldn't hold it in place, so you were constantly looking at it hanging down one side or another in the rear view mirror.
Then the sun came out. My professionally trimmed headlining proceeded to peel itself off as the glue gave way in the heat. To be fair, trimmer did say he would do it again. As yet I have been unable to make myself go through the ball ache of removing the headlining etc again. Had I known this in advance, I think I would have just gritted my teeth and shelled out for a new one.
MJVR6
MJVR6
  • 2956 posts
  • LocationHerts/NWLondon
Im in the same boat mate, Im in need of it being re-done, Sagging a little above my head and around the sunvisor, been quoted the same, £500 just to get the job done.
Following a guy on Insta, seems to know his shizzle, probably do it soon......
MJ
MJVR6Insta: @DjMj73
'Built Not Bought'.
Krankenshafter
Krankenshafter
  • 99 posts
Dragging this back up again.
MJ - did you get your headlining done yet? My car looks like a shed with lining hanging off all over the place.
I am not on the face book groups, but does anyone have a 2 door sunroof headlining they are getting rid of? Any recent breakers?
Cheers - Chris.
  • MJVR6 likes this
kgw
kgw
  • 54 posts
As a temp measure, use straight pins to flatten it out:
I did this on an older Caprice I owned. Parking outside in the heat of the SoCal sun kills the adhesive that the headliners depend on... You won't have to look at drooping cloth while you go about your business. hi.gif
HPA DSG tune, UM ecu tune, Shrick 268/264 cams, Tarox 6-pot/discs
MJVR6
MJVR6
  • 2956 posts
Cheers - Chris.
Still needs doin bro..
MJ
MJVR6Insta: @DjMj73
'Built Not Bought'.
