MK4 R32 Tornado Red (HPA Turbo) - For Sale - R32OC | VW Golf R32, Golf R and other .:R Vehicle Owners Club.
  • This topic is locked This topic is locked
6 replies to this topic
Jaeger_R32
Jaeger_R32
  • 498 posts
MK4 R32 Tornado Red - HPA Turbo
A rather emotional post for me, with possible parting of my ever loved R32T, a project that has been the most delightful experience over these past years. Having just moved houses, growing kids and space becoming very confined, I may need to consider an alternative set of wheels / project. As any passionate R32 owner, I’d only wish for this to land in the hands of another very enthusiastic person who would appreciate the machine she is today. Thus with no rush from my side, I’ll put it out there to see if there are any people out there with an appetite for a turbo’d R32. The collated specs I have so far are below. For any more info or pics, feel free to PM me. I can also share pics as need to setup some links to show them here.
· EFR 7670 Single Scroll Borgwarner Turbo
· ROTHE R32 Turbo Ansaugbrücke KURZ Manifold (Additionally purchased Rothe Intake)
· HPA Cast Exhaust Manifold
· HPA 70mm Downpipe to link to the Stock cats
· Electronic Boost Controller
· Stainless Steel Heat Shields
· 3mm Head Spacer Plate
· Modified Chain Guide
· 500cc Injectors
· Custom Silicon Hoses
· 3 bar FPR
· Intercooler fitted
· Proprietary Software by Autograph Tuning (Agents for HPA)
· Oil and Water Braided Lines
· Nuts, Bolts, and Gaskets included
· Recent new FEB23142 Engine Mount and 1J0199851AM Engine Mount
· Relocated ambient temp sensor to front air flow
· CSF Race Radiator
· Run with Evans Fluid
· Scorpion non-res cat back exhaust system
· Milltek Sports Cats
· Bilstein B14 Adjustable Coilovers
· Short Shifter Linkage
· Upgraded Turbo Actuator
· Profec Greddy Digital Turbo Boost Controller
· Upgraded Fuel Pump
· Upgraded RS6 Air Intake and MAF – 100mm
· Induction Cone Filter intake
· New Rear OEM Calipers
· Tarox Brake Lines with front Strada Pads and rear Strada pads
· Sachs Performance Pressure Plate
· Sachs Performance Organic Friction Disc
· LUK Dual Mass Flywheel (LUK Flywheel Bolts & Bearings)
· Neuspeed Cool Thermostat
· New Coolant Housing Fitted
· Head off to be shaved/skimmed/reface, pressure tested and cleaned with new valve stems replaced
· Pro-tech Fuel Pressure Regulator
· New Lambda Sensors Fitted
· New Brake Master Cylinder fitted with full front brake service
· New Timing Chains fitted with new sprocket, seals, pins, tensioner, rail
· Upgraded Colour Display for Vehicle Parameter Readings and Diagnostics
· 454bhp / 5963 rpm and 466 lbft / 4483 rpm
· 81K Miles covered
· £16,500
41375524-10155431193011504-2119156006515
Whats-App-Image-2020-02-10-at-23-39-36.j
Edited by Jaeger_R32, 21 February 2020 - 01:07 PM.
  • G60Dub likes this
2004, Tornado Red, Induction, HPA Mapped, Spacers, B14 Bilstein Coilovers, Tinted Front Lights, Splitter Kit, Carbon Front Grill, HPA Turbo Coversion and Intercooled
MJVR6
MJVR6
  • 2957 posts
  • LocationHerts/NWLondon
GLWS Uncle B..
MJ
MJVR6Insta: @DjMj73
'Built Not Bought'.
sixteen10
sixteen10
  • 151 posts
Have you got any pics? Sent from my iPhone using Tapatalk
Jaeger_R32
Jaeger_R32
  • 498 posts
Hi Sixteen10, I do have a range of pics
Maybe PM me your email address and I can send a few there if that helps.
Bernard
Andy
Andy
  • 3484 posts
Can you up load the pics on here as it will sell better
Jaeger_R32
Jaeger_R32
  • 498 posts
Will do Andy. For some reason when I clicked the insert pic and entereed a link to my google drive pics, it did not reflect anything. So not sure where I'm going wrong. Will keep trying though and hopefully get some up soon
Jaeger_R32
Jaeger_R32
  • 498 posts
Thanks Andy, pictures sorted now !!
Hope these give some better visuals for Peeps here .
