Mass air flow sensor - Performance and Technical - R32OC | VW Golf R32, Golf R and other .:R Vehicle Owners Club.
3 replies to this topic
lee005
lee005
  • 266 posts
Hi I've been getting a few fault codes related to my MAF
000258 - mass air flow sensor (G70)
P0102 = 002 - Signal low
01314 - Engine control module
             013 - check DTC memory
I think the second fault goes away when the first fault is fixed, I've had the fault for a few weeks now, I did buy a brand new MAF and I'm still having the same fault, when I used VCDS I was getting a very low G70 g/s reading and now it just reads as zero no matter what MAF I use, all the wires seem to be plugged into the female D connector that goes into the MAF, any ideas what I can check next?
Uniquer32
Uniquer32
  • 38 posts
Maybe sensor in the MAF needs a clean blast?
omaru
omaru
  • 1 posts
Hi, might want to check the wiring to the maf as could be damaged a bit further back
msk.dating
msk.dating
  • 1 posts
легкие отношения
