MK4 ball joints - mayle brand ok ? - General Chat - R32OC | VW Golf R32, Golf R and other .:R Vehicle Owners Club.
13 replies to this topic
Gti Fly
Gti Fly
  • 5440 posts
I'm looking at refreshing my front suspension.
VW want £66 for a ball joint each , plus vat I think.
eBay I've found the correct part number comes up with a mayle made ball joint.
It's 66 on eBay for 2 ball joints and 4 bushes for the lowe control arms.
Which would you go for ?
Edited by Gti Fly, 14 August 2020 - 08:26 PM.
Gti Fly
Gti Fly
  • 5440 posts
Infact I've seen you can get meyle, lemforder. Febi,
Does anyone know what VW use for OEM ?
Sabaselfsit
Sabaselfsit
  • 620 posts
  • LocationBergen, Norway
Have changed ball joints on both my mk4 R32 and mk4 tdi 4motion golf in the past and have always used aftermarket. Meyle and Febi are good quality. Never heard of Lemforder. It is the cheaper options you should watch out for. Some of which actually come without a hex in the middle - which make them hard to install as the bolt will spinn around before the nut is tight (and impossible to take apart again - only option to cut off with a grinder)
After installation I always sprayed the bracket and the 3 bolts with body spray to prevent them from rusting to much, and they will come off more easy next time a change is due.
smp
smp
  • 273 posts
  • LocationDorset
If you ever get the answer, I would like to know. I need to replace them on one of my MKIVs
Gti Fly
Gti Fly
  • 5440 posts
I think I'm just gonna get from VW .
I've already bought 2 new front lower arms for £260. F it. The cars served me well never had to change those parts b4.
smp
smp
  • 273 posts
  • LocationDorset
Me too.
I bought bottom arms from VW so I could get my wheel alignment sorted, only to find the ball joints were seperate.
illegalr32
illegalr32
  • 174 posts
Lemforder is on top, but meyle is just as good.. Just don't go with optimal or some kind of cheap shit haha
Gti Fly
Gti Fly
  • 5440 posts
So lemforder are good
How about febi-bilstien. That's another brand that comes up too
Gti Fly
Gti Fly
  • 5440 posts
Me too.
How much did the bottom arms cost you ?
My local VW told me they were 260 per side ...
I got them for half that on eBay !
I noticed on one of the Arms, the rear bush is just starting to peel away at one side when it was jacked up and we were changing the top mounts.
My mechanic said just get new OEM arms to save faffing around , and at £130 each it worked out fairly decent price as I was actually looking at getting cookbot bushes but it quickly works out to be more expensive than just getting brand new OEM arms and just be done with it. I mean 17 years on the OEM arms/bushes, can't complain really
smp
smp
  • 273 posts
  • LocationDorset
Yeah,  I think it was £200+ each. Like your mechanic said, much easier to buy new arms with bushes, than try to replace the bushes in  knackered old arms. I bought VW top mounts at the same time. I still haven't fitted them because  I just assumed the ball joint came with the arm. So hurry up and find out what brand are OEM !
Edited by smp, 17 August 2020 - 08:18 PM.
Gti Fly
Gti Fly
  • 5440 posts
Lol. I think I'm just gonna go OEM for the ball joints tbh . Have u considered going for the seat Leon cupra r top mounts ? OEM fitment but they are harder rubber than the R32 ones.
I fitted the Leon ones to mine a few weeks ago , no complaints.
Gti Fly
Gti Fly
  • 5440 posts
Ok, so just an update
The MK4 R32 ball joints are made by trw.
Trw is what my car came with from factory, and trw is also what VW parts have supplied too.
So if anyone else is in same boat as me, u can buy trw off eBay !
  • smp likes this
smp
smp
  • 273 posts
  • LocationDorset
Thanks for the update. I bought mine from VW, but will shop around for TRW next time.
Gti Fly
Gti Fly
  • 5440 posts
No worries glad it helps
