PCV Valve in the rocker cover BFH code...help pls - Performance and Technical - R32OC | VW Golf R32, Golf R and other .:R Vehicle Owners Club.
4 replies to this topic
ALB-R32
ALB-R32
  • 15 posts
Good evening all, I have 2004 Golf R32 BFH engine code, I'm having PCV valve problems, I have already currently replaced the air intake pipe PCV valve, my mechanic has said we need to replace the PCV valve in the rocker cover.
Unlike other 3.2 R32 engines I'm struggling to find a repair kit to replace the PCV valve in the rocker cover for my engine code (BFH).
Can anyone help with this?
This post is linked to ‘ MK4 R32 down on power, manifold ballooning, help please’
Many thanks
AB
kgw
kgw
  • 46 posts
Try here:
https://vanos-bmw.co...429d-3-6-fsi-v6
  • ALB-R32 likes this
HPA DSG tune, UM ecu tune, Shrick 268/264 cams, Tarox 6-pot/discs
DubNurd
DubNurd
  • 237 posts
  • LocationWhangarei, NZ
The MK5 has the PCV pressure regulating diaphragm in the rocker cover and the outlet is connected to the vacuum side of the throttle body.
the MK4 is on the "atmospheric" side of the throttle body, and doesn't have the diaphragm. It just has a basic oil separation system in the rocker cover (glorified pot scrubber to condense the vapours). There may be a leak somewhere though.
Did you replace the entire external pipe? There is a valve is the little crossover pipe.
Allan
My non-Golf .:R32
ALB-R32
ALB-R32
  • 15 posts
Thanks for the info, very much appreciated!
so no need to hunt for something that doesn’t exist ( the pcv valve in rocker cover I mean)
I’ll check out those pipes when I have a minute.
The rear exhaust is blowing a little ( corrosion and unfixable really) would this have anything to do with my issues of a flat spot around 2500/3000rpm?
She likes this cold weather from start and then the flat spot appears again when warm....lasts a few miles
Many thanks
AB
kgw
kgw
  • 46 posts
