which coil pack? - Performance and Technical - R32OC | VW Golf R32, Golf R and other .:R Vehicle Owners Club.
which coil pack?
8 replies to this topic
kingswood
kingswood
  • 1010 posts
  • LocationHull
cars starting to cost money :-/
had the aux belt and pulls done so took her on a decent drive yesterday and the rev counter is stuttering under  load and can feel the engine hesitating.
last time this happened it misfired and EML lite up. was a misfire in cylinder one when coded. so reset the codes and had new plugs fitted as part of a service.
all ok until yesterday. assume its the coil pack again as everything else is ok. could just replace coil one but I suppose the rest may not be far behind and I suppose its only money :-(
which ones shall I buy? seems to be a big price difference online at different places
Gti Fly
Gti Fly
  • 5484 posts
I'd only suggest OEM , but they are like £50 quid each. That recent hot engine you had probably was enough to bake the coil over the edge.
  • MJVR6 and kingswood like this
ChrisR32Blue
ChrisR32Blue
  • 273 posts
I've had similar before, replaced the coil only to find it was the spark plug.
If it's been a while I'd think about replacing them first. Mine were just over 30k miles old, think they are recommended to be changed every 40k.
kingswood
kingswood
  • 1010 posts
  • LocationHull
cheers for the replies. shall I just change bank one and see how it get on?can get the £43 each with mates ups discount. will end up being £300 fitted at mates rates.
Andy
Andy
  • 3414 posts
Scan it and change that one for now then do the rest but that is just me
MJVR6
MJVR6
  • 2948 posts
  • LocationHerts/NWLondon
Do it yourself, 5min job mate.
MJ
MJVR6Insta: @DjMj73
'Built Not Bought'.
G60Dub
G60Dub
  • 794 posts
  • LocationAberdeenshire
Beru and Bosch coils are both fine. if shopping about should be able to get a set of six for about £180-£190.
Bora R32 More-Commotion
kgw
kgw
  • 52 posts
I've been running a set of Denso coils in the vr6...no problems.
HPA DSG tune, UM ecu tune, Shrick 268/264 cams, Tarox 6-pot/discs
kingswood
kingswood
  • 1010 posts
  • LocationHull
2f84299e6e1f29f6cb6d180b698292cd.jpg Plot thickens.
Took the car to my mates to get the codes read.
Turns out to be then G28 sensor :-/
Doin some reading seems to be a ‘go to’ code for the car which covers a few things.
Easy enough to change according to a few posts.
And £22 from europarts. So will get round to changing that
Sent from my iPhone using Tapatalk
Edited by kingswood, 18 February 2021 - 07:50 PM.
