MK5 MIXING COOLANT IN OIL - Performance and Technical - R32OC | VW Golf R32, Golf R and other .:R Vehicle Owners Club.
Vehicle
8 replies to this topic
Ihaveanmk5r32
Ihaveanmk5r32
  • 4 posts
Hello people, my first ever post!
I have an MK5 R32 mixing coolant inside the oil-not vice versa...
Any idea if there’s a common issue or do I begin doing a head gasket with a new chain?
Thanks!
cuprabob
cuprabob
  • 19382 posts
Head gasket is pretty rare on this engine, more than likely to be the oil cooler.
Ihaveanmk5r32
Ihaveanmk5r32
  • 4 posts
Thanks ever so much. I’ll get it looked at!
cuprabob
cuprabob
  • 19382 posts
One thing to note that in cold ambient temperatures and if the car is used for short journeys you can get white milky deposits around the oil filler cap as the engine doesn't get earm enough to burn off the condensation. Some people mistake this for coolant mixing with the oil. If you genuinely have coolant mixing with the oil dùe to a failed oil cooler or head gasket, the coolant level will drop.
Ihaveanmk5r32
Ihaveanmk5r32
  • 4 posts
We only dry store it in our garage and start it twice a month.... hasn’t been driven more than 100 miles for the year.
Haven’t noticed much drop in coolant. I’ll probably start with oil cooler.
Thanks again
cuprabob
cuprabob
  • 19382 posts
Well if that's the case, it will probably be the fact it's being started twice a month and the engine oil never gets warm enough to burn off the condensation and it's emulsifying in the oil giving the impression of coolant in the oil. My money is on there not being an issue but good luck and come back and let us know what you find.
Edited by cuprabob, 08 March 2021 - 09:15 AM.
  • MagnusV6TT likes this
ChrisGR32
ChrisGR32
  • 72 posts
Agree with Cuprabob.
Clean the oil cap of any emulsification, take it for a long drive. Check oil cap when you get back.
Ihaveanmk5r32
Ihaveanmk5r32
  • 4 posts
Thanks to both, I will be taking it out in august time so until then, I’ll keep you updated!
DubNurd
DubNurd
  • 250 posts
  • LocationWhangarei, NZ
Stop starting it up, if you aren't going to drive it.
That's WAY worse that leaving it for months without starting. Creates moisture and acids in the oil that start corroding things.
Allan
My non-Golf .:R32
Also tagged with one or more of these keywords: Vehicle
