Mk5 Top Mounts - Performance and Technical - R32OC | VW Golf R32, Golf R and other .:R Vehicle Owners Club.
Mk5 Top Mounts
1 reply to this topic
xannaya
xannaya
  • 4 posts
Just ordered a set of coilovers and looking for top mounts. Are the TTRS ones still the go to upgrade ?
Anything else I should think about replacing while im doing the upgrade ?
VelovetAndy
VelovetAndy
  • 386 posts
  • LocationDerbyshire
Depending upon what coilovers you have bought, check that your drop
inks will fit correctly. Some coilovers require a different drop link but yours should say if they do. Be prepared to replace other items as you go about the job. Hard to say what exactly but it could be any or all of lower ball joint, drive shaft boot, discs and pads, wheel bearings , wishbone bushes , track rod ends etc and at the rear, ditto .
