First problem appearing was my Lambda sensor light appearing on the dash. It's an intermittent fault that will disappear and reappear at random but clears when you disconnect the battery.
A short while later the interior "reading" lights that come on when you open the door but should dim once you start the ignition wouldn't go off. If you switched the right one on the left one would go out but if you did it the opposite way the right one stayed on. Pulling the bulbs caused the central light to stay on so I've pulled it as well.
and now the bloody boot won't unlock itself and the cylinder where you put the key doesn't let you get the key in so can't open it even manually. It did this once before but opened up the next day so thought it was just the cold giving me grief but I'm not so sure now.
Could it be an electronics issue/grounding fault?
This is really starting to annoy me, any suggestions?
