Hey guys.
Well since the cold weather has come in, I've realised my car isn't starting aswell as it could be. It's been like the last 3/4 weeks, I've noticed the secondary air pump isn't coming in. When I used to start the R in the cold, it used to raise the revs to just about 1000 for about 30-60 seconds. Which I presume is like pulling the choke out on the older cars, giving it that bit more fuel for when it's really cold. But it hasn't been doing this recently at all, it fires and then nearly stalls, the 9 times out of 10 manages to start normal tickover. Although one cold day in work last week, I started it, it fired and then did actually stall. I presume this is because the secondary air pump isnt working? I've read there is a relay under the bonnet, do you think this could be the cause?
Any ideas? Must be bad cos even my mum and Mrs have noticed it nearly dies when starting, starts fine once engine is warm. Just the initial cold start.
Cheers guys!
Ash
Cheers guys!
Ash
